RIght side smoking??
SIDECAR77
Post by SIDECAR77 » Mon Aug 17, 2009 7:56 pm
Finally got my superhawk running just right, and now the the right exhaust started smoking but not the left suspect vavle to be the problem or ring, smoke is gray going to try adjusting vavles and see what happens. Is it possible to have only one ring worn and not the other
pete lloyd
Re: RIght side smoking??
Post by pete lloyd » Sun Aug 23, 2009 9:37 am
SIDECAR77 wrote:Finally got my superhawk running just right, and now the the right exhaust started smoking but not the left suspect vavle to be the problem or ring, smoke is gray going to try adjusting vavles and see what happens. Is it possible to have only one ring worn and not the other[i have a similar problem smokes when cold but the smoking stops when when hot i think it might be that the valves getting worn and drop when cold letting the oil thats in the head drip into the cylinder i'm going to strip it down soon and check this out if you have any ideas let me know and if i find anything out i will pass it on/quote]
chico
smoking
Post by chico » Mon Aug 24, 2009 11:00 am
my passed experience in smoking engines on start up cold and stop when warm was worn valve guides. chico
pete lloyd
right side smoking
Post by pete lloyd » Sat Aug 29, 2009 12:31 pm
yeah i think thats the problem just got a copy of the parts list for the bike and the general honda service manual for all bikes upto 1988 so i'm going to pull it down and have a look over the next week
pete lloyd
right side smoking
Post by pete lloyd » Sun Sep 27, 2009 12:24 pm
I have stripped the engine down valve guides are perfect and the piston rings are the same . The only thing i found to be wrong is the pipe that run's form the inlet valves ( out side the head join's the valves) was blocked on the side that was smoking . When i have got it back together i will let you know if it has made any difference .
Post by davomoto » Sun Sep 27, 2009 12:47 pm
Pete, as Honda eliminated those vents later in production, I think your problem lies elswhere! Are you installing new rings? The machine shop by me can machine the top of the guides, and install oil seals. It sounds to me like your issue was due to valve guides.
Post by G-Man » Sun Sep 27, 2009 1:33 pm
Pete
Have you had a look at the head gasket? If everything else really is hunky-dory, I wonder if you have a substandard gasket or o-rings around the oil feed. I would vote for valve guides but it might be something else letting extra oil into the exhaust.
cron
