Need Help! Fuel coming out exhaust on right side?
Hi I am newbie at this so bare with me. I set timming per ed moore, bike fires up first kick both cylinders fire at first and then right dies out and fuel starts to come out at header joint bike stays running, lean out fuel an nothing, rev it up to 4000 and right starts to work, then dies out shortly after, what am I doing wrong.
kustommusic
You are probably not doing anything wrong,except you didn't tell us what you have. I'm assuming its a two carb model, CB or CL 305. You need to look into the carb on the right side. It sounds like the float needle is stuck and allowing way too much fuel in. Fix that and clean up the spark plug on that side and it may be OK. Let us know! Good Luck, Kustommusic
Sorry, its a 67 superhawk, thanks for the info going to check that tomorrow I don't know why I didn't when I set floats. I've been doing some reading on this site and there is another post that says it could be the slow jet plugged or passage? I guess I check that while I'm there anyway.
Thanks Jason
Thanks Jason
Pin seems to be fine, soaked carbs for a day blew out all holes and put back together, seem to have same problem?? drop it off at the shop for them to take a look. Does anyone know of a mechanic that is really good at working on these older jap bikes in ontario?? I'm findind it hard to find anyone that will touch this bike.
kustommusic
Jason, Ed Moore might be the one to fix you up, try him. EMO@ktc.com
Kustommusic
Kustommusic
Flood! Where's Noahs Ark
Just got bike back 2 weeks ago form the mechanic bike ran great idle around 800-900 no smoke perfect! 2-3 days after bike floods itself and now will not start, am I doing something wrong or should I bring it back. well at least theres no fuel coming out of exhaust, oh ya another ? I bought a gasket kit and the exhaust gasket are the brass ones right and there are 4 just want to confirm how they go on and there are some rubber gasket same size ?? not the valve cover gasket these have a slight taper where do they go. help would be much appreciated thanks guys.
