shift drumshift drumMy superhawk has been hanging up between 1st and 2nd gears. I pulled the mill, took bottom pan off and found the shift drum on 2nd gear point is chipped. Has anyone tried taking a dremel and polishing the point smooth? Would this let the transmission want to jump into 2nd gear upon acceleration? Any thoughts would be appreciated. I suppose an nos drum would be like hens teeth? thanks nutt
shift drumthanks davemoto, I had one more dream bottom end to tear apart. finally did this weekend and the drum and forks look perfect, so I'll use them. Thanks for the offer. nutt
