Header pipes for the CA77
joeweir1
Post by joeweir1 » Wed Mar 07, 2007 4:04 pm
There is an "S" marked on one my headers where it enters the muffler.Does this mean anything?thanks- Joe
4shorts
Post by 4shorts » Fri Mar 16, 2007 6:59 am
Joe I got into my shed and found the other original header pipe. One of the pipes has the letter "S" on the end of it. It's bent lower than the other side and is 1 inch shorter
The other pipe has an "L" marked on it. Paul
joeweir1
Post by joeweir1 » Fri Mar 16, 2007 8:04 pm
Thanks Paul-Now did the "S" come from the right?
Maloymerc
Post by Maloymerc » Fri Mar 16, 2007 11:54 pm
4shorts wrote:Joe I got into my shed and found the other original header pipe. One of the pipes has the letter "S" on the end of it. It's bent lower than the other side and is 1 inch shorter
Is the header pipe really shorter than the other?
I just thought mine was cut off coz it was wrapped in rubber when i got the bike.
mjmudd
ca77 header pipes
Post by mjmudd » Fri May 18, 2007 3:25 pm
So...Does the longer header pipe go on the right / brake side?
Mike
