connecting rod sleeves?
Post by G-Man » Sun Jan 11, 2015 3:29 pm
Phil
That's really interesting. I'll look forward to seeing your findings.
SMBH
Post by SMBH » Sun Jan 11, 2015 7:18 pm
I too have a spare crankshaft all the bearings are ok it is just the two small ends that have play in them.
Resleeving would solve a lot of problems and cost, im no engineer unlike our G-Man but the rods are iron and not alloy is not iron stronger than alloy and would iron not be better for sleeving ?
I too look forward to any findings.
seespotweld1
what is to much
Post by seespotweld1 » Tue Jan 13, 2015 12:30 pm
what would you consider to be to much play ?I think I might have the same issue
SMBH
Re: what is to much
Post by SMBH » Tue Jan 13, 2015 2:00 pm
seespotweld1 wrote:what would you consider to be to much play ?I think I might have the same issue
I can not say how much play but just to say in my experience a very light hand press of the pin through the rod and piston with no up or down or rocking of the pin once installed.
Any movement and you will get a light tinkling sound on light throttle openings, well I did. After changing the crank for one with very less movement in the pin with only the slightest of play I now have only the very slightest of tinkling sound on light throttle openings and I can live with that.
I know a good engineer that may elaborate more on this.
seespotweld1
Re: what is to much
Post by seespotweld1 » Tue Jan 13, 2015 2:48 pm
actually i thought my engine to be very noise free ..aside from the usual kind of busy sounding top end noise ..no noticeable wear on the pins ...but i do get a slight rocking with the new pins ..more than i have noticed on other rebuilds ...always something to worry about
Farm Shop
Post by Farm Shop » Tue Jan 13, 2015 8:04 pm
The specs in my clymer read as such,
New pin 15.mm
Rod end 15.016 - 15.043
If greater than 15.1 replace
Fs
seespotweld1
Post by seespotweld1 » Wed Jan 14, 2015 4:21 pm
Farm Shop wrote:The specs in my clymer read as such,
New pin 15.mm
Fs
thanks for that
cron
