Ok More help needed
Post by LOUD MOUSE » Mon Feb 18, 2008 7:43 pm
Ride it a while and see if maybe (you're lucky) the smoke is oil in the exhaust system. ................lm
britman wrote:
davomoto wrote:Are the slides in the correct sides of the carbs? The cut-out in the slide should be facing towards the rear. If you install them backwards, the bike won't run right. What position is the clip on the needles in ? Try second highest.
davomoto,
I OWE YOU A BEER. Checked the slides today, they were reversed. Apparently the previous owner had stitched them during the last carb rebuild, so I would venture a guess, the bike has been sitting for quite awhile. Being used to British, where the cut out faces out, I thought they were correct. After the change, she runs great. It does smoke some on start up, so I would say a top end job will be forthcoming. Thanks Dave, Loud Mouse, and all of the rest on this site who have helped a "New" "Old Honda" owner get a good start on bringing one back. Let the tear down begin.
britman
Test Ride-CL77
Post by britman » Sun Feb 24, 2008 10:48 am
Yes I know how down right ugly the bike is, Caveman on the tank included, but I took it out for about a fifteen mile ride test drive today. Did a compression check (135/136 on cylinders with a cheap JC Whitney tester), and final tweaking on carbs and ignition before leaving the abode. With my cell phone in my jacket to call the wife to bring the trailer if needed and a borrowed antique tag from a Bonneville off I went. It runs pretty darn good. Smoking died down, but I know with the compression check numbers I will need rings sooner than later. I had forgotten how low these bikes are geared and I think my speedometer may not be accurate (somewhere in the 20 to 30 mph error range.) I have to fix the horn button today, that is the only thing not working on the machine, so I am pleased. It is a blast to ride and I may keep in this form as I start to tear down the parts bike. This motor is going into the parts bike frame to produce a semi matching numbers machine and to to a good phased rebuild starting from frame up. It will also give me an opportunity to ride the old "Caveman" to the first warm bike night to see what kind of reactions it will get.
