Front fork
305CL77Texas
Front fork
I moved this to correct section under suspension
Re: Front fork jamed
See my reply in suspension section. You don't need to post in more than one section as were easily confused..... :-)
305CL77Texas wrote:Close to many year project on my 67 Cl77
One of the front forks is jammed and will not move up and down
Has anyone taken the bottom seal off looks like there may be a special tool
to clip into two holes on the bottom assembly to unscrew the sealed area
Not sure if this is clear trying to disassemble the bottom tube where the spring is located to find out why it is jammed
305CL77Texas
G-Man wrote:See my reply in suspension section. You don't need to post in more than one section as were easily confused..... :-)
