cylinder vents?
MANATEEBREATH
cylinder vents?
Post by MANATEEBREATH » Fri Dec 28, 2007 10:24 pm
I have the original breather hose that runs from the top of the head, only had a slight split on the top end, spring clamp still on it. I trimmed it and reinstalled clamp. Original angle cut on bottom end is still there. Because it is so old the shape showed me the routing. still long enough to poke out the hole above counter sprocket.
I assume the 2 outlet nipples on the back of the cylinders are to have hoses routed to the air filters?
OH, its a cb77 sorry. 1965. I didnt find those hoses in any of my boxes.
also where should the bowl vent hoses dump out?
thanks.
1966 CB77
ggray
hoses
Post by ggray » Fri Dec 28, 2007 11:16 pm
Manatee,
Yes, hoses go to the filters if your filters have fittings for the hoses. If not, loop a single hose between the two barbed fittings to close the air circuit.
I believe I read where Loud Mouse said to leave the bowl vent hoses off.
Gary
'65 CL77 Owner
Re: cylinder vents?
Post by LOUD MOUSE » Fri Dec 28, 2007 11:35 pm
OK with the top hose and the others at the inside of the carbs go to a "Y" then to the right side filter.
The carbs WILL NOT HAVE any tubes on them. .................lm
MANATEEBREATH wrote:I have the original breather hose that runs from the top of the head, only had a slight split on the top end, spring clamp still on it. I trimmed it and reinstalled clamp. Original angle cut on bottom end is still there. Because it is so old the shape showed me the routing. still long enough to poke out the hole above counter sprocket.
thanks.
MANATEEBREATH
Post by MANATEEBREATH » Sat Dec 29, 2007 8:56 am
ok cool, I was gonna put clear hoses on the bowl vents.
My air filters, original I beleve both have a fitting for a hose.
still use a t to the right filter?
1966 CB77
Post by LOUD MOUSE » Sat Dec 29, 2007 8:59 am
The "T" will make the bike correct but there is no problem using both air cleaner fittings. ........................lm
MANATEEBREATH wrote:ok cool, I was gonna put clear hoses on the bowl vents.
MANATEEBREATH
Post by MANATEEBREATH » Sat Dec 29, 2007 9:04 am
thanx, Ive seen the "t" for sale somewhere before.
cool.
1966 CB77
