CB77 right cylinder not firing properly
Jim Stuart
Post by Jim Stuart » Mon Nov 26, 2007 5:46 pm
I don't know if I am doing this correctly, but I just unstored my 1967 CB77 305. Upon starting, following timing and plug instructions, I find the right cylinder is not firing properly. Compression seems good, plug does foul. Air adjustment screw does nothing. Left cylinder fires well, and air screw does have effect. Do I have a carb float problem on the right?
Thanks, Jim
Re: CB77 right cylinder not firing properly
Post by LOUD MOUSE » Mon Nov 26, 2007 6:48 pm
You have a plugged slow speed jet. .........................lm
Jim Stuart wrote:I don't know if I am doing this correctly, but I just unstored my 1967 CB77 305. Upon starting, following timing and plug instructions, I find the right cylinder is not firing properly. Compression seems good, plug does foul. Air adjustment screw does nothing. Left cylinder fires well, and air screw does have effect. Do I have a carb float problem on the right?
Thanks, Jim
Jim Stuart
Right Carb 305
Post by Jim Stuart » Sat Dec 15, 2007 1:51 pm
O.K. Guys, I need help. The right carb, which has been cleaned many, many times is still not cooperating. I fire it up, and the left is running fine. Did all the tuning stuff. The air jet has almost no effect. If I turn it all the way in, and begin backing it out, I will get a couple fires out of the cylinder. Other than that it has no effect. The idle jet is clear, I did a compression check this morning and both are in the 120# range. I am sure I am overlooking something simple. Any comments??
Thanks,
Jim Stuart
    Re: Right Carb 305
    Post by LOUD MOUSE » Sat Dec 15, 2007 2:51 pm
    Gas in the bowl?
    Plugged slow speed passage?. ...............lm
    Jim Stuart wrote:O.K. Guys, I need help. The right carb, which has been cleaned many, many times is still not cooperating. I fire it up, and the left is running fine. Did all the tuning stuff. The air jet has almost no effect. If I turn it all the way in, and begin backing it out, I will get a couple fires out of the cylinder. Other than that it has no effect. The idle jet is clear, I did a compression check this morning and both are in the 120# range. I am sure I am overlooking something simple. Any comments??
    Thanks,
    Jim Stuart
      Jim Stuart
      Re: Right Carb 305
      Post by Jim Stuart » Sat Dec 15, 2007 3:03 pm
      LOUD MOUSE wrote:Gas in the bowl?
      Thanks,
      Jim Stuart
        There is gas in the bowl. Have shot thru Carb cleaner and its clear. Everything is clean, just as in the left carb.
        Jim
        Re: Right Carb 305
        Post by LOUD MOUSE » Sat Dec 15, 2007 4:51 pm
        Well if the caeb is OK then it heads to the top of the engine.
        Valves! Points set correctly. Spark at the plug.
        Good Luck. ............lm
        Thanks,
        Jim Stuart
          Jim
          Jim Stuart
          Re: Right Carb 305
          Post by Jim Stuart » Sat Dec 15, 2007 5:17 pm
          LOUD MOUSE wrote:Well if the caeb is OK then it heads to the top of the engine.
          Thanks,
          Jim Stuart
            Jim[]
            I will check valve clearance tomorrow. If they were not correct, would I not get good compression??? Spark jumps a 1/4" gap with a spark tester. I have a set of 8 plugs now, due to replacing them every time I do something different.
            Jim
