Flywheel Puller Question
Steverino
Post by Steverino » Mon Jan 25, 2016 10:49 pm
I need to pull my flywheel to replace my rollers and springs. Does anyone know the brand and part number of a good purpose built puller for the CB77?
Thank you
Steve
jas67
Re: Flywheel Puller Question
Post by jas67 » Mon Jan 25, 2016 10:55 pm
Steverino wrote:I need to pull my flywheel to replace my rollers and springs. Does anyone know the brand and part number of a good purpose built puller for the CB77?
Thank you
Steve
Yes, you do. I'm not sure of the brand and part number of the one that I have, but, IIRC, I got it from Bike Bandit. It fits a LOT of different Hondas, including CB175/CL175 with the vertical cylinders, as I've used the same tool on those as well.
This one should do the trick:
http://www.amazon.com/BikeMaster-Magnet ... uller+16mm
rrietman
Post by rrietman » Tue Jan 26, 2016 1:03 am
-you can use the rear axle to pull the rotor. or any other bolt with the correct rh threads.
Randy
Steverino
Post by Steverino » Tue Jan 26, 2016 1:20 am
Thank you. Thing that bothers me is that I used to know that. Too many whacks to the head in my younger days.
Steve
jas67
Post by jas67 » Tue Jan 26, 2016 6:45 am
rrietman wrote:-you can use the rear axle to pull the rotor. or any other bolt with the correct rh threads.
Randy
Having the right tool in the toolbox is a bit more convenient than pulling the rear axle.
But, this is good to know if you want to get the rotor off today, and don't want to wait for the tool to ship. It isn't likely you'll find an M16-1.5 bolt at your local hardware store.
DianneB
Post by DianneB » Tue Jan 26, 2016 8:13 am
Should be the same as my C77 - I believe all I needed was a 16mm bolt - cost me less than $2.
jas67
Post by jas67 » Tue Jan 26, 2016 8:30 am
DianneB wrote:Should be the same as my C77 - I believe all I needed was a 16mm bolt - cost me less than $2.
Yep. I think most 60's and 70's Hondas all have the same size thread to remove the flywheel.
