Adventures on the Old Girl, and with the Old Girl
Post by LOUD MOUSE » Thu Aug 20, 2015 3:38 pm
Just don't lay it on it's face.
Evaporates?. ............lm
G-Man wrote:That should help. You just need to make sure you don't get too much lube wicked into the speedo as it can discolor the face if it evaporates in hot weather.
sarals wrote:I've pulled out the instrument cluster and I have it sitting in a shallow container of 30W oil. LM suggested I do this to allow the oil to wick up into the mechanism of the speedo and tach. Hopefully it will cure the "needle bouncing" that the speedo is doing. This is a last resort before I bite the bullet and send it to a repair outfit...
R100
Post by R100 » Thu Aug 20, 2015 3:46 pm
That's kinda how I did mine Dianne.
I first put WD40 in that area, let it sit for a while, then a couple of cleanings with contact cleaner and a gentle compressed air stream.
After that I did what you are doing.
Started with a non-functional speedo and a completely erratic tach. Now they are both working perfectly.
sarals
Post by sarals » Fri Aug 21, 2015 8:54 am
Well, I left it in the oil for just over 24 hours. It's now sitting upright (on, no - not going to lay it down!) on a towel to drain out excess. Later this morning/afternoon I'll put it back in the bike and cross my fingers!
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
Post by G-Man » Fri Aug 21, 2015 10:46 am
Yep - all oils are made up of different 'fractions' that's how they are separated in the production process.
The brown discoloration on the faces of speedos is largely evaporated and re-condensed lube.....
LOUD MOUSE wrote:Just don't lay it on it's face.
Post by G-Man » Fri Aug 21, 2015 1:34 pm
You'll have a nice smooth action, hopefully.
sarals wrote:Well, I left it in the oil for just over 24 hours. It's now sitting upright (on, no - not going to lay it down!) on a towel to drain out excess. Later this morning/afternoon I'll put it back in the bike and cross my fingers!
Post by LOUD MOUSE » Fri Aug 21, 2015 1:54 pm
Or sun burned paint.
Or oil for being left with the face down. .............lm
G-Man wrote:Yep - all oils are made up of different 'fractions' that's how they are separated in the production process.
Post by G-Man » Fri Aug 21, 2015 9:09 pm
Sara
Just watched your video. That's really neat. Are you using a GoPro, or something else?
How do you mount (or carry) it?
sarals wrote:Here is the promised video:
https://youtu.be/ewUDanrMzaI
A little bit about it. The speedometer isn't working! It was yesterday, not today. I checked the cable after the ride, and it's fine. So, the problem is likely the gage. I'm going to have to pull the unit out and send it to Foreign Speedo, I guess. That's something I didn't want to do. But, it has to work, and I really don't feel like ripping into that gage cluster again.
I'll take the bike out for a longer ride, perhaps this evening.
Enjoy!
