While refreshing My CL77 for the comming riding season, I found My exhust pipe mount bolt hole in the side of the frame wasted from the PO's ovious overtightening and cross threading. I decided to drill the old threads out and install an incert to fix the problem. Now I find out the hole already has a Heli-Coil in it and My cobalt 24/64 drill bit will not cut the stainless coil. Has anyone ever sucessfuly removed a Heli-Coil by sawing, drilling, fileing or any other type of extraction.
Fast Fred
Heli-Coil Removing
Heli-Coil Removing
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
Hard to believe somebody screwed up a Helicoil by cross threading a bolt into it. My guess is the used a metric bolt with an SAE insert or vice-versa. They are spring steel so pretty hard to bugger up. I think I'd clean it out really well with a blast of air and maybe a bore brush and then take a close look at the threads. Might be a UNF insert and a mating UNF bolt will go in nicely.
regards,
Rob
regards,
Rob
SUCCESS
SUCCESS, I first went to Heli-Coil's webpage and saw the special removal tool they offer, it's basicly a triangle shaped sharp chisel that you tap into the stainles coil and turn counter clockwise to screw the coil out. Sounded easy enough. Problem was I had tried to drill the thing out and by so doing , I really screw up the first couple of coils and I was unable to catch enough of the first coil to use this method. I could see the installation tab was still attached so I stuck a small hemostat thru the coil , grabed the tab and screwed the coil clockwise to screw the coil thru the hole to the other side where it fell into the fram rail. Done deal. Thanks to all who replied to my post.
Fast Fred
Fast Fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
66 CL77
76 CB550FKR
76 CT90
