Carburetor intake insulator and o-ring damage
garncarz
Post by garncarz » Tue Apr 08, 2014 3:48 pm
Assuming these are the same as the one on the CA77 there are 4 new ones in stock at http://www.westernhillshondayamaha.com/
Snakeoil
Post by Snakeoil » Tue Apr 08, 2014 5:27 pm
Problem solved.
Regarding Western Hills Honda, the owner is profiteering off the backs of the vintage owners. I cannot remember what the part was, but I had called them and they said they did not have it, but would locate it. I then called around, found a dealer that had it, but said Western Hills just bought it. I called Western Hills back and the price was something like 5 or more times the list price. I could have bought it for Honda list had I called the other dealer first.
Terry, the parts guy at WHH is okay. He said there was nothing he could do about it. The owner sets the pricing policies.
I bought a lot of parts from them. But they are now my last resource if I cannot find it anywhere else.
regards,
Rob
garncarz
Post by garncarz » Wed Apr 09, 2014 7:19 am
Antique vehicle ownership is a pricey hobby. This is my fisrt vintage Honda and frankly I am amazed (read, happy as a pig in shit) that you can call up a dealer, check a nation-wide parts locator network and order 50 year old NOS OEM parts....at any price. For a parts cost and availability wake up call, try owning a 1930's vintage wooden powerboat.
brewsky
Post by brewsky » Wed Apr 09, 2014 5:54 pm
Rob,
Good job on the gaskets.
Whenever I have to make any, I soak them in oil first brfore using.
Don't really know why, just seems like a good idea???
Snakeoil
Post by Snakeoil » Wed Apr 09, 2014 7:28 pm
Thanks. I have a lathe so I can make punches any diameter I want.
regards,
Rob
moondoggers
O ring
Post by moondoggers » Wed Apr 09, 2014 9:30 pm
O ring faces out to the carb flange to seal against air leaks not against the hot cylinder head.
Hoosier Tom
Re: O ring
Post by Hoosier Tom » Wed Apr 09, 2014 9:47 pm
moondoggers wrote:O ring faces out to the carb flange to seal against air leaks not against the hot cylinder head.
Not sure you are understanding the setup of the spacer. There are two o-rings used to seal each carb to head. There is an o-ring between the carb flange and the outboard face of the spacer and then a second o-ring between the inboard side of the spacer (sets in a machined groove) and the head. Rob's issue was on the inboard side of the spacer where the o-ring resides in the machined groove that seals against the hot cylinder head from air leaks.
HT
