CL 77 Carb slide springs
moondoggers
Post by moondoggers » Sun Oct 27, 2013 9:17 am
My throttle twist grip has zero return when open. Are new springs available?
rustywrench
throttle
Post by rustywrench » Sun Oct 27, 2013 10:48 am
The springs are most likely not the problem here. Start with checking the friction of the cables, make sure they move freely, then make sure the cable to twist grip is cleaned and lubed and also the grip may be rubbing on the end of the bar. Loosen the grip and move it down the bar a bit. Hope this helps ya, Rusty
