lower crankcase oil leak
dreamhog
Post by dreamhog » Mon Jul 15, 2013 10:04 pm
I have developed a significant oil leak at the lower crankcase right side. Does the lower case use a gasket i need to order before i pull it off? Also what all will i need to remove before pulling the lower case?
[/b]
conbs
Oil leak
Post by conbs » Mon Jul 15, 2013 10:58 pm
Hard to tell where your leak is from your post.
There are several seals under the right engine cover. No gasket on the cover, so you can pulls it off to get a better idea where the oil is actually coming from.
Let us know.
dreamhog
Oil Leak
Post by dreamhog » Tue Jul 16, 2013 2:34 pm
I dont mean for this to be a "DUH" type reply but if the lower crank case does not use a gasket then I assume my only option is to remove it, clean it, apply some form of sealant and reassemble ? Also do I have to remove either (or both) side cases to get the lower case off ?
conbs
Oil leak
Post by conbs » Tue Jul 16, 2013 5:21 pm
1. Yep. Search this site for lots of discussion. Hondabond, Right Stuff, etc.
2. Yep. You could turn the bike over and just remove the bottom case without removing the engine from the frame. Again, search this site for discussion.
You will want to look at it closely to see where the leak is and why it started so suddenly. I wouldn't rule out the seals until you know where the leak is.
When you use the search function, click the "posts" icon lower left and try different combinations of words.
dreamhog
thanks
Post by dreamhog » Tue Jul 16, 2013 9:14 pm
thanks conbs i will give some thought to turning the bike upside down vs pulling the engine.
Also. .. Fyi... Im going to be in Salmon Idaho next month. Is that anywhere near you? Its a long way from N Mississippi
conbs
Salmon, Idaho
Post by conbs » Wed Jul 17, 2013 8:48 am
In Salmon Idaho you will be in one of the most beautiful places on God's green earth. I live in the SW Idaho desert about 5 hours away. It looks nothing like Salmon. Some people can find beauty in sagebrush but, I am not one of them.
Tinman
Re: Salmon, Idaho
Post by Tinman » Wed Jul 17, 2013 10:58 am
conbs wrote:In Salmon Idaho you will be in one of the most beautiful places on God's green earth. I live in the SW Idaho desert about 5 hours away. It looks nothing like Salmon. Some people can find beauty in sagebrush but, I am not one of them.
Fruitland/Marsing?
