Back brake cable CL77 correct length??
jsmith1107
Post by jsmith1107 » Fri May 31, 2013 7:12 pm
Can someone please measure their back brake cable? I bought a cable and the person I bought it from said it was correct, it seems short in terms of the cable inside of it. The measurement on mine is 26" long. Is that correct?? I searched for it on this forum but couldn't find it.
Thanks in advance.
Jeff
1974 Yamaha DT125 Enduro
1974 Harley Davidson AMF X90
1976-7 Yamaha XS 650
2-1966 Honda Scrambler
1973 Suzuki T500 Titan
mike horvath
Post by mike horvath » Fri May 31, 2013 8:41 pm
J,
My cable literally measures about 26" long and the arc is about 4-1/2" above the top of the swing arm and lines up right into the support on the brake panel with the brake pedal just below center of the stator cover.
Hope this helps.
jsmith1107
Post by jsmith1107 » Fri May 31, 2013 8:47 pm
ok, well the length is right I guess. Maybe I am not putting it on correct. Do you have any pics of yours where it goes on the back brake hub and then on the spot where the back brake switch is? I looked at some pictures of other bikes and I see how it goes on I think but it just doesn't want to fit correctly. Do you have the measurement of how much cable sticks out of each end after the rubber accordion style part?
Thanks for your help.
Jeff
mike horvath
Post by mike horvath » Fri May 31, 2013 10:38 pm
Jeff,
On my set up, there is about 4" of cable showing on the brake switch side and roughly 2-3/4" showing on the brake panel side. The threaded adjuster is at it's maximum travel (to the left) with no threaded portion showing beyond the brake panel support collar and out board lock nut. With this set up, the brake pedal travels maybe 1-/12" down before engaging the brakes. If I can get some pictures I'll send 'em.
jsmith1107
Post by jsmith1107 » Sat Jun 01, 2013 8:11 am
Mike,
Thanks a lot for you help, it is much appreciated. So, that 4 inches and 2.75 inches you are talking about must include the accordion looking rubber piece. I guess I will just go at it again.
Jeff
mike horvath
Post by mike horvath » Sat Jun 01, 2013 11:54 pm
Correct. Once the complete cable is set in place and adjusted, the accordian looking protectors cover the exposed portions of the steel cable at either end right up to the pivoting swivel attachments. The darn picture files wouldn't load.
mike horvath
Post by mike horvath » Sun Jun 02, 2013 2:04 pm
Jeff,
hope these images help! Sorry the images came out cock-eyed...oh well.
overall view
overall view
foot brake
foot brake
rear brake panel
rear brake panel
