I've got a 61 dream that has takes the narrow style battery and I want to try out one of those new dry batteries, I think they're lithium. I've seen them on ebay for the late dream. Has anyone used on in an early dream? Will it fit?
Thanks,
Paul
61 CS72
Has anyone tried to fit one of those new "dry" bat
- Paul Strassmaier
CB72, CL72, CS72, CYP77
C71,JC57,D, 4E, Z50m
Haven't tried one, but did some research on them. You can damage them if you go above 14.4 volts, not a good thing since the dream has no voltage regulator and will go above that. There's more information on this thread;
http://www.honda305.com/forums/lithium- ... t9326.html
I went with the AGM battery. It fits in my early Dream with room to spare and plenty of cranking power. I used the battery in this link;
http://www.honda305.com/forums/agm-batt ... t7936.html
63 CA78
Early Dream Battery
Paul, G-man put up a post with a link showing a guy that altered the battery hold down to accept a battery that is a little taller. That battery is readily available. That mod probably deserves consideration.
Also, before you give up on a battery, try de-sulfating it.
- Paul Strassmaier
