Sorry to post so much 160 stuff in here, but you all are much more knowledgable than the other forums.
Finished my rebuild, put the cam chain and clip on and now the engine won't turn over.
Well, it will if the valve adjusters are all the way out, but if you screw them in even a little, the whole train stops at the top of the cam lobe on each valve.
It's like the cam is too big (stock) or the springs won't compress (stock reused from before rebuild), or something is blocking the valve from opening in the chamber.
It's so tight, the bolt on the rotor came loose rather than turning the engine over.
My first thought was the pistons are contacting the valves, but it holds up after you pass TDC and both pistons are on the way DOWN.
Anyone have any ideas?
The head is pretty simple, and I assembled the head and valves by the book.
Another 160 problem
Sounds like you may have the cam timing wrong.
Does it turn over OK with the cam chain off?
Is this the motor with the 175 pistons?
Have you got a 175 head gasket?
If you have 175 pistons how do they compare with the originals?
Photos, photos, photos.......
Confirmed with flashlight that pistons are exactly at top when rotor read TDC.
Cam chain seems right from visual inspection from top and with bottom square cover off.
It's on the sprockets, sitting on the large tensioner wheel squarely.
Also confirmed all valves opening and closing as you turn the cam, with the valve lash set to something crazy loose, like a 1/4 inch. Any tighter and it hangs up.
Still baffled.
Still baffled.
CAM TIMING!. .........lm
Jlovvorn wrote:Confirmed with flashlight that pistons are exactly at top when rotor read TDC.
Still baffled.
