c92 vin number
c92 vin number
I cant find frame number on a c92.It is a 1962 flat bar model and I was told that it should be under the toolbox on the l/h side any help would be appreciated.
Re: c92 vin number
bill-vfr wrote:I cant find frame number on a c92.It is a 1962 flat bar model and I was told that it should be under the toolbox on the l/h side any help would be appreciated.[/quote
Me too I have same problems ,anyone can help us?
- Paul Strassmaier
It's been awhile, but as I recall, it is verticle (read from the ground up) and pretty low, below where the swingarm mounts.... Good luck, they can be tough to read. I've noticed that pressed steel bar (domestic bikes) have the year in the center of the number (C92-62-XXXXX)....
CB72, CL72, CS72, CYP77
C71,JC57,D, 4E, Z50m
Thank you Paul ,Paul Strassmaier wrote:It's been awhile, but as I recall, it is verticle (read from the ground up) and pretty low, below where the swingarm mounts.... Good luck, they can be tough to read. I've noticed that pressed steel bar (domestic bikes) have the year in the center of the number (C92-62-XXXXX)....
Re: c92 vin number
up100 wrote:bill-vfr wrote:I cant find frame number on a c92.It is a 1962 flat bar model and I was told that it should be under the toolbox on the l/h side any help would be appreciated.[/quote
] It is a very fine stamping below the toolbox but unfortunetly it gets rubbed away by the movement of the chainguard. If you have the original engine the frame number is usually within a few numbers away
