Carb. Gasket
joeweir1
Carb. Gasket
Post by joeweir1 » Fri Apr 20, 2007 7:13 am
What is the best sealent to hold the bowl gasket on? thanks
Hahnda
Post by Hahnda » Fri Apr 20, 2007 8:33 am
None?
joeweir1
Post by joeweir1 » Fri Apr 20, 2007 10:25 am
Then whats to keep it from movig while putting the bowl back on after I work on it on the bike?The original seemed to be held in place with something?thanks
Hahnda
Post by Hahnda » Fri Apr 20, 2007 10:35 am
Doesn't your carb have a flange on the body? If the gasket falls off when I remove the bowl, sometimes it does, sometimes it doesn't, I just put it on top of the bowl and then place the bowl back on the carb. The flange helps to align it if I remember right.
Re: Carb. Gasket
Post by LOUD MOUSE » Fri Apr 20, 2007 10:43 pm
New gasket. .......lm
joeweir1 wrote:What is the best sealent to hold the bowl gasket on? thanks
kustommusic
Post by kustommusic » Sat Apr 21, 2007 8:14 am
Just DON'T use silicone! That stuff is not good around gasoline. Steve Greer
Post by LOUD MOUSE » Sat Apr 21, 2007 8:19 am
The (glue?) Honda used was to keep the gasket in place as the carb was assembled.
When the gasket needs to be replaced a NOS one will stay in place because the prongs for the float shaft will hold it. .....lm
joeweir1 wrote:Then whats to keep it from movig while putting the bowl back on after I work on it on the bike?The original seemed to be held in place with something?thanks
