How to run a CB77 without a battery?
56_oval
Post by 56_oval » Thu Apr 05, 2012 1:34 pm
Just what it says. Is there a way? And I'm not talking about using one of those little boxes, I mean completely batteryless. Kickstart only and electrics run off of stator...
Post by davomoto » Thu Apr 05, 2012 2:34 pm
I've done it with a computer grade capacitor, but haven't managed to get a working headlight yet. The excess power from the stator needs to go somewhere, so the "battery eliminator" fills that need.
Davo
Hotshoe
Post by Hotshoe » Thu Apr 05, 2012 4:58 pm
There's a way to convert a stock 305 dyno (with battery) to a magneto (no battery).
I had a racer in the 60's that had one and the bike in the photo has one.
Don't know how it's done or if that would accomplish what you're trying to do.
If you're interested, my pal who owns the bike and I had talked about reverse engineering it next time I'm out in SoCal, maybe next month.
56_oval
Post by 56_oval » Thu Apr 05, 2012 5:05 pm
I'd love any info available. Did you convert that bike to right hand shift as well? If you could fill me in on that as well, that would be awesome. After the wreck, the left foot doesn't work so well...
Hotshoe
Post by Hotshoe » Thu Apr 05, 2012 10:34 pm
I'll let you know what I find out about the magneto conversion.
Sorry about your foot but I'm not sure if the right side shift is a practical conversion.
It was originally done for a flat track engine (turn left, go fast, repeat), I'll ask the current owner if he knows anything about it.
Bill Engvall thought of the day..... how about converting your Superhawk shift linkage to a hand shift?
brewsky
Post by brewsky » Fri Apr 06, 2012 6:08 am
Haven't tried it myself, but worth a look:
http://www.oregonmotorcycleparts.com/BEC.html
mike in idaho
Post by mike in idaho » Sat Apr 07, 2012 10:08 am
Hotshoe wrote:There's a way to convert a stock 305 dyno (with battery) to a magneto (no battery).
I did it with a pair of Honda 50 coils and re-wiring the alternator. You need to separate the connections in the alternator harness and re-wire it to combine one daytime coil and one lighting coil to run each side. I used the early Honda a/c type ignition coils and oversize(Mallory) condensers. The spark advance needs to locked at full-open, so the magnets in the rotor are lined with the stator coils when the points open, to get the most spark energy. With the advance working it's almost impossible to kick start.
'65 YG1
'65 CB160
'66 CL160
'66 CL77
'78 XS650
'79 GL1000
'69 T100R
'68 TR6
'69 T120
'72 750 Commando
my company car is a Kenworth
