carb Problems CA77
L; good idea on buying a new float. when the float is raised up in the carb by fuel level, to it's high point, it shuts the needle valve ( the small pointy thing in the threaded brass seat with the metal washer). at that point no fuel flows into the carb. as the running engine draws fuel in, the float sinks, opening the needle valve, allowing fuel to flow into the carb. if the float doesn't rise (leaky--full of fuel), the fuel flows continously, overflowing.
Good luck
Randy
Good luck
Randy
- jleewebb
LM right again!
lewarcher wrote:the part that slips into it with the pointy part that rides on the float? quote]
I think LM's spotted the problem here...pointy end goes up into seat, flat part (with spring loaded plunger on my bike) rides on float tang...assuming we're reading you right...
'62 CB77. "It's a rider."
