light stays on open or closed points
G-GAURD
Post by G-GAURD » Fri Jul 09, 2010 1:37 pm
well i was wrong my circuit light stays on when the points are open and closed so something is wrong i just got the bike and i want to make sure that i'm not gettingt in over my head so can someone please tell me what i need to replace if the light stays on whether the points are open or closed??
Re: light stays on open or closed points
Post by LOUD MOUSE » Fri Jul 09, 2010 1:42 pm
When the points close they cause a ground to be at the wire location and the 12 volts is grounded and ya should not read voltage..
Are the points clean?
Do they really make contact?. ...........lm
G-GAURD wrote:well i was wrong my circuit light stays on when the points are open and closed so something is wrong i just got the bike and i want to make sure that i'm not gettingt in over my head so can someone please tell me what i need to replace if the light stays on whether the points are open or closed??
Post by davomoto » Fri Jul 09, 2010 7:05 pm
Make sure the fibre washers are keeping the wire from grounding out. Also should be a fibre collar
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
G-GAURD
i dont think the collar is fibre
Post by G-GAURD » Sat Jul 10, 2010 12:08 am
it looks like this from left to right
nut--wire--leaf spring--then what looks like a thin shim--fibre washer--a washer--fibre washer--bolt head
i took a picture but the site says its to big 1.2mb
how can i condense it and post it here ?
Gunner_CAF
Post by Gunner_CAF » Sat Jul 10, 2010 1:12 am
You will need a graphics editing program that can resize the picture. The one I like for quickly editing or resizing a picture for posting is called IrfanView. It's free and you can find it if you search download.com.
http://download.cnet.com/IrfanView/3000 ... ?tag=mncol
Open the picture with it. In the menu under Image select Resize/Resample. I use 640x480 pixels or if I want it a bit bigger 800x600 Pixels. Press OK then save it as a JPG file. Either of these two sizes normal get you under message board size limits.
There are many other graphics editing programs around that will do the same thing. I use other more powerful programs, but I use InfanView what I when I want to do a quick edit to reduce the size for posting or e-mail.
Gunner
G-GAURD
i unscrewed the bolt
Post by G-GAURD » Sat Jul 10, 2010 1:47 am
i unscrewed the bolt and found all the fibre washers and barrel i also cleaned the contacts and i still get power all the time open or closed now i have removed the horn so i can look at the condenser and it looks dirty and the the metal wire clamps are touching the head cooling fins so i'm gonna loosen it and roll it up to break contact.
i downloaded the infaview and i hope this picture will load up of my points so here goes
brewsky
Post by brewsky » Sat Jul 10, 2010 3:58 am
Is the points wire contacting the plate where it bends to exit the cover?
Looks like some corrosion there.
