would safety switch prevent spark?
G-GAURD
do these pictures look correct?
Post by G-GAURD » Fri Jul 09, 2010 11:15 am
i tried to send a photo of the points but it takes up to much space
from left to right it goes as follows
nut--wire--leaf--fibre washer--lead to plate?--fibre washer--bolt
i did the circuit light to the leaf spring on the points and its getting power when i rotate the crank and the points seperate and no power when the points close.
i'm gonna get a new coil just to be sure it was only 40 sum dollars from JC whitney but until it arrives i will check all the wiring and see if i can get a spark
paperslammer
Post by paperslammer » Fri Jul 09, 2010 1:31 pm
'64 CA77 305 Dream
