Revs Up when I turn left
Onemilewest
Post by Onemilewest » Sun Jan 31, 2010 9:20 pm
I am almost embarrassed to ask this one, but I have re-ran the throttle cable twice. I have a 305 Dream. 1965. When I turn left the motor revs up. Any hints?
Onemile
Gunner_CAF
Post by Gunner_CAF » Mon Feb 01, 2010 12:39 am
You may have a cable that is to short or not routed right. After I put my Superhawk back together, I had a similar problem when I turned hard right, the clutch would disengage. The cable was pulling tight when the handlebars were turned all the way and this was enough to disengage the clutch. The same thing could happen with the throttle.
Gunner
Dgormley
Cable
Post by Dgormley » Mon Feb 01, 2010 11:36 am
Onemile, I have to agree with Gunnar, the only time I have ever experienced your problem was due to routing of the cable or wrong cable length. Does your cable run inside the handlebars?...........D
Onemilewest
Post by Onemilewest » Mon Feb 01, 2010 1:19 pm
Yes. I now have it coming out the left side, through the wiring harness tab, into the first hole in the frame. Through the inside of the frame all the way to the carb. I put short bars on so I know my cable is about 4" too long, but it revs up when I turn into the cable?
Post by e3steve » Mon Feb 01, 2010 5:17 pm
Try backing-off the cable adjuster(s) a turn or so. Or adjust the cable, with the steering hard-over, so that there's a smidgen of play in the throttle before it starts to lift the carb slide.
Just a thought....
Onemilewest
Post by Onemilewest » Mon Feb 01, 2010 5:35 pm
Thank you for the input. I am out of ideas and need the help.
Gunner_CAF
Post by Gunner_CAF » Mon Feb 01, 2010 10:22 pm
Another thing you can try is to move the levers in about a quarter inch. I did this for my clutch lever and it did the trick.
Gunner
