Starving of fuel somehow
Greggie-e
Post by Greggie-e » Wed May 27, 2009 2:10 am
Hey all,
I have an intermittant problem and I am not sure if it is just a regular problem with the model.
My CA77 will run fine with the fuel tap on Reserve, but if I run it switched to "on" it will occasionally starve of fuel, usually when I am giving it stick.
I have stripped the tap down and there are no blockages in the tap at all.
The only thing I can think of is that the reserve inlet is lower than the "on" inlet and thus has a slightly greater pressure....
So is this a regular issue that I have to live with or is there a fix?
Apart from replacing the tap with a fast flow tap of course.
Cheers,
Greg
Re: Starving of fuel somehow
Post by LOUD MOUSE » Wed May 27, 2009 6:58 am
YOU ARE CORRECT THAT THE RESERVE INLET IS LOWER IN THE TANK THAN THE ON INLET.
HAVE YA REMOVED THE UNIT AND CHECKED THE INLET TO SEE IF IT'S OPEN/PLUGGED?. ........lm
Greggie-e wrote:Hey all,
Cheers,
Greg
DONZIE
Post by DONZIE » Wed May 27, 2009 9:19 pm
PUT MORE GAS IN THE TANK !
Greggie-e
Post by Greggie-e » Wed May 27, 2009 10:31 pm
What I did is:
I removed the tap, dissassembled.
Visually checked for obvious blockages, I coule see none.
I soaked the metalic pieces in carbi cleaner for an hour to make sure, then blew it all out with compressed air.
Then I reassembled and blew compressed air through again.
Reinstalled.
The same problem occured.
Could it be that my bike could do with a tune, and thus is using more fuel than it should?
I have tuned it myself, but I have never had it done professionally (and I don't really want to either)
It rides pretty well. Top speed is around 110km/h (68 mph) It does occasionally give a small pop, but I put that down to the fact it needs a new seal between the left exhaust and header pipe.
