CA77 Carb Rebuild
joeweir1
Post by joeweir1 » Sat Jun 21, 2008 2:01 pm
Did you check and make sure your ground on the frame is clean, also the battery terminals clean and tight?Does anything at all work-Horn neutral light.
grom
Post by grom » Sun Jun 22, 2008 12:51 pm
The ground seems pretty solid, and the battery is new, so everything is clean. I went out the next day, and the same thing happened. My brother suggested that the battery might be just strong enough to run the lights and the engine for a few seconds, but that my electrical system is not supporting it at all. I've misplaced my horn, so I couldn't test that, and I don't believe my neutral light works, period. I'm charging the battery, and will try to start it without the lights and see what happens.
joeweir1
Post by joeweir1 » Sun Jun 22, 2008 7:02 pm
Are you still using the stock rectifier?It may be causing to drain your battery.I switched to a soild state one from Radio Shack for a few dollars.Make sure all connections from stator are ok also.
grom
Post by grom » Sun Jun 22, 2008 8:24 pm
To my knowledge, all of the electrical system is bone stock save for the lack of a starter button. The stator connections seem adequate. I may look into this solid state business, it sounds promising. There's nothing quite like 45 year old motorcycle wiring. Thanks for the support.
grom
Post by grom » Wed Jun 25, 2008 2:46 pm
An update. As it turns out, the second idling attempt did blow the 10a fuse from the battery. I replaced the fuse and made sure that there are no loose/bare wires contacting any metal. There were a few suspect places where the horn wire cover was a little thin, so that may be where the trouble happened. I then started the bike, and attempted to steady the idle. Just trying to find the right combination of idle screw and air screw to have it run without a hand on the throttle. I ran out of time before the idle steadied, but at least the bike is running. I've also taken to disconnecting the battery in between starting attempts.
