Clean inside of engine.
Eddie46
Post by Eddie46 » Tue May 22, 2012 5:23 pm
Would damage occure if I was to flush oil resivore with kerosene or deisel?
Ed
Goodysnap
Post by Goodysnap » Tue May 22, 2012 6:21 pm
I assume you mean while still assembled in running condition. I have done so in the past on many different engines. I ussually add a solvent of your choice to the oil. Drain some off before hand if you choose. I prefer not to exceed 25% dilution. I only run at idle for 10-15 min , then allow to thoroughly drain. Clean out the filter after draining.
To answer your question. If done wrong yes it sure could.
64' CB77
65' CB160
Eddie46
Post by Eddie46 » Tue May 22, 2012 9:36 pm
Thanks Goody,
Thinking of only cranking not starting.
Ed
