cylinder head bolt torque/failure
here's one that I have not had happen before. torqueing up a head and this one started twisting at 18 (I normally go to 22-24 and always lube the threads). checked for the nut bottoming out (OK) . tried again and it broke at 21. granted it's the thin outer front, but still? I guess it was just tired after 50 years.
Randy
Randy
jensen
- Contact:
The specified torque is always dry, not lubed. When you lube the thread, the torque is way to high. Make sure the threads are clean and dry, also the engine case threads.
I torque these dry on the specified torque, and after running once, I torque them again, and after a couple of 100 miles, I turn every nut 20 degrees further. Some people get the studs out with a gripper, or other pliers. Once the surface of the stud is damaged, the stud can snap under much lower torque than the specified setting, caused by tearing.
gbyoung2
True that, and I know the CL77 engine I'm presently working on has been into at least once. I intend to kinda "sneak" up on the main head bolt torque and go from there - BUT - do have a question: what torque are ya'll putting on the 10mm nuts that sit under the plugs? Haven't found a spec for those in the Manual.G-Man wrote:After 50 years you don't know what the history of that stud has been it may have been overtorqued on many occasions.
OldScrambler
Ericvanrijn
And, what is the specified torque? It is not mentioned in my service manual! Can someone please help me with this info?jensen wrote:Hi,
Book shows:
13.74-16.63ft-lb.
I go 21. ........................lm
13.74-16.63ft-lb.
Ericvanrijn wrote:And, what is the specified torque? It is not mentioned in my service manual! Can someone please help me with this info?jensen wrote:Hi,
