some times you have to look end of story
the inside is about 99% rust free and in great condition, could not believe it!!! good every thing ,a small amount on the crank throws and thats it, now the crank is still stuck in there cause of the rusted cylinders and will probably be rusted by the time I get it out due to exposer to the air, I wd as much as I could, but I feel blessed with what i got out of the bike for my $100, good small brake hubs, good forks, throttle assm.carbs for part,s spare trans, shift assm,. clutch assm. one hd lite ear, axles, seat pan, engine mounting hardware, and a set of oem baffles that I still have to get out of the rotted pipes, clutch cover, head cover, swing arm, so Iam getting close to having enough to do up my 63 250 scambler, after cleaning up things to day I was looking at the trans gear dogs 3rd and 4th show very little use witch kind of confims my thoughts that it was used only in the dirt and rarely used the two higher gears, teazer I will try and post some pics of the left overs, my camers is very old and low res, just for you doubting thomasas
