Oil leak from behind camshaft left/right end covers
JSchuster15
Post by JSchuster15 » Wed May 22, 2019 6:24 pm
I have an oil leak from the gasket between the end covers and the cylinder head. Can these gaskets be replaced without removing the head or head cover? Engine is still in the bike. Looks like it is just 4 bolts and the points need to be removed from the right side. Anything else?
'66 CL77
'64 CA77
Re: Oil leak from behind camshaft left/right end covers
Post by LOUD MOUSE » Fri May 24, 2019 4:32 pm
Do yo have leaks at both ends of the head?.. ...................lm
JSchuster15 wrote:I have an oil leak from the gasket between the end covers and the cylinder head. Can these gaskets be replaced without removing the head or head cover? Engine is still in the bike. Looks like it is just 4 bolts and the points need to be removed from the right side. Anything else?
Littlewin
Post by Littlewin » Sat Aug 12, 2023 7:45 am
Did you solve that oil leak issue, and if so what was the case of the leak
