Hello: recently restored 1966 honda scrambler starts and runs well. after about 5 minutes it stalls and engine dies. why? how do I prevent this from happening?
Thanks...tmansk
stalling 1966 cl77
CL77 stalling
When it has stalled how do you get it running again, does it start up again OK?
Could be that the vent hole in the fuel cap is blocked, there was a Honda mod to drill a second vent hole 180 degrees opposite the original so that the rubber / cork seal can't block both holes at once.
Try running it without the fuel cap or loosen it after say four minutes and see if that helps.
