Anyone know the torque spec on the stator bolt crankshaft torque spec. None of my manuals list it.
Thanks
                    Stator Crankshaft Bolt Torque
				qwispichkn
2016 HD Streetglide Special
2010 HD Fat boy
1965 Honda Dream CA77
2006 Kawasaki Klx250S
						2010 HD Fat boy
Torque setting.
I assume we're talking C/CB/CL72 series?
I've never had one come loose with just sensible hand tightening and certainly never used a torque wrench on one.
If you want a torque setting I'd go somewhere around 14 - 5 ft lbs ( same as the cyl. head and crankcase studs) and you should be OK.
If you're a real worrier you could add a small dab of LOW strength Loctite or similar.
BTW, the bolt from the later CB250/350 engines is much nicer as it has a good thick 'washer' ready machined under the hexagon.
				qwispichkn
