CA77 Sticking throttle body
hondadreamca77
Post by hondadreamca77 » Sat Apr 28, 2018 11:32 am
Hey Guys,
Searched the forum and decided to post. Throttle body is sticking causing high revs at idle.
New throttle cable/adjusted, carb removed and jets cleaned, etc.
Tips??
68' 305 Dream, 75' Honda 750-four, 74' Honda CL 125, 72' Honda CA 70, 80' Honda Passport, 74' Aerimachi Harley Sprint 125, 64' Yamaha 90.
mike1969
throttle sticking
Post by mike1969 » Sun Apr 29, 2018 6:26 am
Is the throttle slide turned 180 deg. out? This will cause a really high idle.
hondadreamca77
Cable
Post by hondadreamca77 » Sun Apr 29, 2018 3:02 pm
New aftermarket cable is too long after adjustment. Double checked all else.
hondadreamca77
Fixed it!
Post by hondadreamca77 » Mon Apr 30, 2018 2:41 pm
Fixed the problem by carefully milling 1/16" off end of throttle slider at handlebar. Enough to lower the idle rpm to manageable adjusting .
