left cam shaft re-assembly
kawonda750
Post by kawonda750 » Tue Apr 24, 2018 2:39 pm
Do I remove the cam bolt in the left side camshaft to relieve a bit of the pressure on the spline to easily assemble that side to the cam sprocket? Or, do I just bang it in?
The bolt is stuck in there pretty well.
pemdoc65
Post by pemdoc65 » Tue Apr 24, 2018 4:18 pm
You can't remove the bolt from the camshaft with the shaft in place. You can loosen the nut on the end of the bolt, then give it a little tap on the end with a small hammer to loosen the bolt within the shaft half. This will make it easier to remove/install.
kawonda750
camshaft
Post by kawonda750 » Tue Apr 24, 2018 6:29 pm
OK Thanks. I wanted to make sure. I finally did loosen it and it fits better now.
The Honda shop manual really tells you nothing.
Thanks again.
