                    Removing CA77 Engine
				honda carl
I need to remove a CA77 engine to work on it. There are 4 bolts that hold it to the frame: two on top and two on bottom. The top two are easy, but the bottom two are very rusty and difficult to access (the nuts are inside the pressed metal frame). How do I remove the lower two bolts and what tool do you use to loosen the nuts inside the frame? Thanks for any help.
						I would suggest holding the nut (or bolt head, whichever is inside) with a stout box-end wrench or impact socket on an L-handle ("breaking bar") and go at the outside part with another box-end (or L-handle)  and a hammer or impact wrench. It will either come loose or break the bolt - either one works!
				honda carl
Thanks, Dianne. I tried a box end wrench for the inside nut but it was too long and didn't fit. Hopefully, I can find a "stout" one that will fit. Nothing else will work because there is very little space (maybe 2" gap) in between the two inside nuts, so nothing with a socket will work. I tried a box end wrench on the outside bolt head without success. I'll need to remove the stator cover and kickstarter to use a breaker bar.
Thanks for the reply.
