my name is søren and i am from Denmark so hopefully you guys can understand me
I bought (what i tought was) a complet Honda cb72 from 1962. But the engine was far from complet, a hole lot of parts was missing. so i bought a doner engine so now i thought a had all parts for a complet engine. I made a complet engine. Whit new gaskets, bearings, and so on. After the engine was assembled i got it in the frame. I kickstartet it a few times and all seemed fine. But! the next day when i came back to the motorbike, it was dripping oil from the head gasket. I took the engine out and stripped the top of the engine. Both cylinder gasket (top and bottom) was soked in oil. I have been thinking a hole lot the last few days and i can simply not find out why. All bolts and nuts are tightened to the right torque. Please help a confused Dane
doner engine:
Oil everywhere on the gaskets:
Just tried to remove the cylinder top and bottom gasket and tighten the 8 nuts on top (just by hand). The cylinder and cylinderhead cant move. So the studs are not to long. All surfaces are straight:
When i turn the engine over just by hand olie is purring out of the hole i marked whit green. No oil is coming out of the red hole. Am i on to something here? I thought the oil should be coming out of the red hole?
