Pistons
james robert
Pistons
Post by james robert » Sun Jul 03, 2016 8:45 pm
I've been eyeballing this package deal from Classic Honda restoration. They say that the pistons are forged and have less drag then the factory pistons. I just thought i would get some input from the pros before i pull the trigger.
Thank you.
http://www.classichondarestoration.com/ ... d_221.html
Re: Pistons
Post by LOUD MOUSE » Sun Jul 03, 2016 9:05 pm
What they don't say is the Front and Rear Skirts are not as long as the HONDA pistons.
They may wear sooner than the stock HONDA Piston/Skirts. ...........lm
james robert wrote:I've been eyeballing this package deal from Classic Honda restoration. They say that the pistons are forged and have less drag then the factory pistons. I just thought i would get some input from the pros before i pull the trigger.
Thank you.
james robert
Re: Pistons
Post by james robert » Sun Jul 03, 2016 9:13 pm
LOUD MOUSE wrote:What they don't say is the Front and Rear Skirts are not as long as the HONDA pistons.
Thank you.
Thanks Loud Mouse, I'm in no hurry I guess I will keep looking.
Tim Miller
Re: Pistons
Post by Tim Miller » Mon Jul 04, 2016 1:09 pm
James,
I have machined and installed several sets of Wiseco pistons from Classic and they work great. The shirt is 5.82mm shorter but that hasn't given me any problems. I will always take a Forged over a Cast piston any day.
Tim
Thank you.
james robert
Post by james robert » Mon Jul 04, 2016 3:34 pm
Tim, Thank you for the input. I did have one reservation about using forged pistons, I have read somewhere that forged pistons are more dense then cast pistons and take longer to warm up, And they have a tendency to knock in a cold engine. This wouldn't bother me though as i would just allow the pistons to reach the right temperature.
Tim Miller
Post by Tim Miller » Mon Jul 04, 2016 5:06 pm
The alloy use in this particular forging is 4032 (high silicon) and has a lower growth rate than some forging. Actually, I set the skirt-to-cylinder clearance for both Honda ART cast and the 4032 at .002". I have heard no piston slap cold or hot.
Tim
james robert wrote:Tim, Thank you for the input. I did have one reservation about using forged pistons, I have read somewhere that forged pistons are more dense then cast pistons and take longer to warm up, And they have a tendency to knock in a cold engine. This wouldn't bother me though as i would just allow the pistons to reach the right temperature.
james robert
Post by james robert » Mon Jul 04, 2016 5:34 pm
Tim, Sounds good I might get the set soon. I will need the machine work done by someone who knows their stuff. If nothing else I want the engine to be right as i will probably make a few long trips. So i plan to have the crank cleaned and inspected and the cylinders bored and piston and rings fitted. I think i can do the rest my self. Let me know what you charge for your services.
Thank you.
Tim Miller wrote:The alloy use in this particular forging is 4032 (high silicon) and has a lower growth rate than some forging. Actually, I set the skirt-to-cylinder clearance for both Honda ART cast and the 4032 at .002". I have heard no piston slap cold or hot.
