                    What size tap for spark plug CA77
				texasgrape
PO cross threaded one of the plugs.  I need to chase the threads.  What size tap do I need? Plugs are D8HA, 1967 CA77.  Also what about the small amount of fine shavings going down the cylinder?  Is that a concern?  Vacuum them out??  Thanks.
				texasgrape
				texasgrape
Lastly, just a tip to keep shavings (if any) out of cylinder:  I used assembly lube in the big grooves of the tap; it's sticky enough that the shavings stick to it.  If you don't have assembly lube, a thin coating of grease.  Use oil as you tap and don't go for it all at once.  A few threads then back it on out and clean tap, repeat . . . worked for me.
				james robert
