305 dream engine problems
64dreamman
Post by 64dreamman » Wed May 28, 2014 2:55 pm
well im ina bit of a problem, ive rebuilt my engine. new rings gaskets etc I put the cylinder on and it went flawlessly put the head on again flawlessly so I wanted to see if I had good compression, good compression on one side and NONE on the strator side, come to find out the valves aren't seating and I leak tested it and so now heres my question how do I manage to get the 4 screws out of the cam cover withought them stripping?
Hahnda
Post by Hahnda » Wed May 28, 2014 9:31 pm
Do you have an impact driver? You need the kind you whack with a hammer.
SWARDLAW
Post by SWARDLAW » Thu May 29, 2014 10:59 am
Is the problem with the valves leaking just a tight valve lash setting?
Re: 305 dream engine problems
Post by LOUD MOUSE » Thu May 29, 2014 2:45 pm
How did you adjust the valves?. .........lm
64dreamman wrote:well im ina bit of a problem, ive rebuilt my engine. new rings gaskets etc I put the cylinder on and it went flawlessly put the head on again flawlessly so I wanted to see if I had good compression, good compression on one side and NONE on the strator side, come to find out the valves aren't seating and I leak tested it and so now heres my question how do I manage to get the 4 screws out of the cam cover withought them stripping?
