LOUD SLAPPING NOISE WHEN STARTING
Harry
Post by Harry » Wed Apr 09, 2014 9:00 pm
305 CA77- when cranking engine there is a loud sound metal slapping metal about 4-5 hits before engine starts.After starting no noise heard.This does no happen every time starting.No noise heard at RPM,runs fine.I checked timming chain tensioner,ok & starter is not hanging up.
Hahnda
Post by Hahnda » Wed Apr 09, 2014 9:10 pm
It could be your starter clutch slipping. Pretty common to have happen and fairly easy to fix.
Does the sound seem to be coming from the right side?
rrietman
Post by rrietman » Wed Apr 09, 2014 11:02 pm
H; noise is with electric start only? try kick, narrow it down. probably only need to RR starter clutch, check for loose screws, and assemble clutch DRY!
Good luck
randy
Harry
Post by Harry » Fri Apr 18, 2014 8:04 am
Hahnda wrote:It could be your starter clutch slipping. Pretty common to have happen and fairly easy to fix.
hard to pinpoint the noise but I would say right side
Harry
Post by Harry » Fri Apr 18, 2014 8:11 am
rrietman wrote:H; noise is with electric start only? try kick, narrow it down. probably only need to RR starter clutch, check for loose screws, and assemble clutch DRY!
Good luck
randy
The clutch does slip now,dics are worn.Does the clutch stay dry after install?It seems to me that they were wet when I was checking them.
Harry
Post by Harry » Fri Apr 18, 2014 8:13 am
Good luck
randy
Hahnda
Post by Hahnda » Fri Apr 18, 2014 8:15 am
The starter clutch and the clutch are two different things. The starter clutch is pictured above. It uses 3 rollers, springs, and pins. As the rollers wear they tend to slip. Quite common. The clutch that transmits power through the transmission is the one that uses steel and friction plates. Those should have oil on them.
