Gasket Sealant
FishingForTheCure
Gasket Sealant
Post by FishingForTheCure » Fri Feb 07, 2014 2:46 am
If all goes well, I'll be reassembling my 305 motor this weekend. Few gaskets, prints, seals etc all around.
I see lots of different sealants ranging from paste to spray. Opinions or preferences?
Thanks!
Post by G-Man » Fri Feb 07, 2014 6:51 am
Hondabond or Yamahabond 4 on the crankcase halves. Every other gasket assembled without sealant.
FishingForTheCure
Post by FishingForTheCure » Fri Feb 07, 2014 11:34 am
Really .... no sealant on gasketed assemblies. That's suprising. Guess this is my I work on my motor out of necessity rather than pleasure.
Post by G-Man » Fri Feb 07, 2014 11:40 am
Gaskets are there to do the sealing. Putting sealant on them just makes them difficult to get off when you take the engine apart next time.
Nice clean, flat surfaces and quality gaskets are enough.
FishingForTheCure
Post by FishingForTheCure » Fri Feb 07, 2014 2:31 pm
Some of the gaskets I removed came off with no problem. Others were fishting me every inch of the way. One took every tool in my box to remove.
Thanks!
malcolmgb
Post by malcolmgb » Fri Feb 07, 2014 3:06 pm
On gaskets I often use a smear of grease on both faces, it helps hold the gasket and align itself if needed during tightening it also stops the gasket sticking when disassembling.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
linmictil2
gaskets
Post by linmictil2 » Fri Feb 07, 2014 3:36 pm
I have always soaked the fiber gaskets in oil then lightly wipe them off before installing.
Mike
66 CL77
CL100
2 -CB125s
ATC200
