Starter clutch question CA77
mythos0512
Post by mythos0512 » Sun Aug 04, 2013 9:50 pm
Question on the Starter clutch for a 64 CA77. What would be possible causes for the Phillips screws to be sheared off the back of the starter clutch? This is the first time I've ever worked on one and I did some searching to find out about the worn springs. (mine were not there) I do have the rebuild kit on order but I'm worried about other possible issues that could've caused this problem. Any insight would be appreciated.
48lesco
Post by 48lesco » Mon Aug 05, 2013 9:04 am
Sounds like something bound the starter clutch to the sprocket while the engine was running. Maybe rollers, springs, caps, etc. That kind of damage is pretty common. I would just put it together properly with only very light lubricant on the springs and caps, nothing on the rollers. Make sure the knock pin is in place too, and stake the phillips screws to keep them in place.
-48
Hoosier Tom
Post by Hoosier Tom » Mon Aug 05, 2013 3:29 pm
Be sure to inspect the body of the starter clutch for hairline cracks or tears where the rollers reside. If there are cracks the steel will flex and not let the rollers grab the crank well enough for consistent cranking. I have seen this before on starter clutches that had sheared screws.
HT
sarals
Post by sarals » Mon Aug 05, 2013 5:10 pm
You might consider finding a complete rotor/starter clutch assembly and replacing the one you have. Those parts are on eBay all the time, and they're reasonable.
1965 CB77 305 Super Hawk
1989 NT650 Hawk GT
1981 Yamaha XJ550 Seca
rrietman
Post by rrietman » Mon Aug 05, 2013 6:44 pm
one screw vibrates loose, hits the sprocket, breaks, then they all go. that's why the screw heads are staked. a little forever loktite is a good idea as well. pretty common failure on these motors.
Randy
mythos0512
Post by mythos0512 » Mon Aug 05, 2013 8:21 pm
Thank you all for the responses. I will check the hubs for any cracks and will stake the screws when they arrive. I was really hoping to do a restoration on her but situations and a determined individual are requiring me to get it running in two weeks for sale to said individual. I will have another in time. They are beautiful bikes. This could free up my time to start on my cd125 restoration.
mythos0512
Post by mythos0512 » Sun Aug 11, 2013 3:55 pm
update. rebuilt the starter clutch and is working well now.
cron
