Cl77 points cam
Cl77 points cam
Just bought a replacement points camshaft. It has twin lobs. Is that correct? I thought a 305 cl77 only has one lob on the points camshaft. Thanks a million CFL
Re: Cl77 points cam
If the lobs are 180 from each other ya have a DREAM part. .lm
CFL wrote:Just bought a replacement points camshaft. It has twin lobs. Is that correct? I thought a 305 cl77 only has one lob on the points camshaft. Thanks a million CFL
Points camshaft
Thank you for the information. I can still fell a little raise on one side of the cam. Why? Thank you, CFL
Re: Points camshaft
Did you compare it to the original?
It's a points cam and the coil fires when the cam opens the points.
Once open and the coil has fired "no big deal" with these as the dwell has been satisfied and you are good for another go round. ..... .......lm
CFL wrote:Thank you for the information. I can still fell a little raise on one side of the cam. Why? Thank you, CFL
points cam
It's the same cam. It will just fire on an empty cylinder. Thanks again, CFL
