Spray paint from PO on the front rim.
Best way to remove spray paint without damaging the chrome.
Any thoughts are appreciated.
Thanks.
Paint Removal from Chrome
S90 / CB550 / CA 77 Dream 305 / Yamaha RT2 360
Rickytic
Quidger, try to put some lacquer thinner on a rag and start wiping. Usually, this works, if not, get some liquid paint remover and try that. The paint remover usually makes a big mess but will mostly wash off with water. If you have a pressure washer, after the paint remover, blast the rim with the pressure washer. Hopefully this will work for you.
Rickytic
Rickytic
