installing new cam chain for cl77
CFL
Post by CFL » Thu Sep 06, 2012 10:00 am
I just bought a new cam chain from EK for my cl77 and it doesn't fit. It is about a half a link to short. The seller says I am doing something wrong. My old chain fits just fine. Anybody have a reason for it not fitting. Also, when I turn the cam chain one complete revolution or two it moves one link forward from the dot on the cam sprocket. Is that normal? Sincerely, CFL Thank you for your help.
Re: installing new cam chain for cl77
Post by LOUD MOUSE » Thu Sep 06, 2012 10:50 am
The link can't stay at the same point on the sprocket with each revolution as the 2 gears are not the same size.
The seller is correct.
The original fits easily as it is stretched from use.
The new one is NEW.
You need to make it fit as long as it is a 94 link. .........lm
CFL wrote:I just bought a new cam chain from EK for my cl77 and it doesn't fit. It is about a half a link to short. The seller says I am doing something wrong. My old chain fits just fine. Anybody have a reason for it not fitting. Also, when I turn the cam chain one complete revolution or two it moves one link forward from the dot on the cam sprocket. Is that normal? Sincerely, CFL Thank you for your help.
48lesco
Post by 48lesco » Thu Sep 06, 2012 12:27 pm
Make up some spacers to put over the studs (10mm nuts work) and tighten the head down slightly until you can get the master link in. You just have to compress the gaskets a little to get it to fit.
CFL
Post by CFL » Fri Sep 07, 2012 8:38 pm
Thank you to all the people that have helped me with my 305 project.
CJ
Post by CJ » Tue Sep 11, 2012 2:47 pm
I trust you backed off the tensioner as far as it would go??
CJ
Post by LOUD MOUSE » Tue Sep 11, 2012 2:49 pm
Ya need to remove the tensioner. .........lm
CJ wrote:I trust you backed off the tensioner as far as it would go??
CJ
