Endless cam chain
motobroker
Endless cam chain
Post by motobroker » Sun Mar 27, 2011 9:10 pm
Has anyone built an engine using an endless cam chain?
I am finishing up my first cl77 rebuild and decided to go with one since they were readily available.
The chain tension was so tight that I had a lot of difficulty getting the cam together.
When I finally managed to get it assembled, the new chain has absolutely no free play and may even be under a slight amount of tension. I even tightened up the head bolts to 12 pounds to help compress the new head and base gasket.
Are these chains supposed to be this tight?
Post by davomoto » Mon Mar 28, 2011 9:01 am
Sounds pretty tight. Try torqing the head bolts to 16 lbs, turn the engine over a few times, and see where you're at. Have you installed the rocker pins yet?
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
Re: Endless cam chain
Post by LOUD MOUSE » Mon Mar 28, 2011 9:44 am
When the chain is new it will be "tight".
Continue assembling and it will be OK. .......lm
motobroker wrote:Has anyone built an engine using an endless cam chain?
motobroker
Post by motobroker » Mon Mar 28, 2011 7:10 pm
I just installed one rocker pin and arm and am doing the other 3 in a few minutes.
Yep, I had to remove the cylinder studs. That was the only way I could figure out how to do it.
I should have at least loosened them before I installed cylinder and head, but I didn't anticipate that issue. Thankfully, I was able to get them all free without snapping them.
I don't think I would recommend using an endless chain if a masterlink one is available. Getting that camshaft installed was very difficult.
By the way, any recommendations for the studs: dry, locktite stud lock, thread lube, whatever?
Post by davomoto » Mon Mar 28, 2011 8:20 pm
Thats' why I asked :-)
By the way, any recommendations for the studs: dry, locktite stud lock, thread lube, whatever?[/quote]
I like using assembly lube
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
motobroker
Post by motobroker » Tue Mar 29, 2011 8:18 pm
Dave,
The assembly lube worked good. Much less friction then with thread lube.
deafanddiabetic
Post by deafanddiabetic » Wed Feb 11, 2015 4:43 pm
Bumping this old dinosaur.
I need to buy a cam chain for my CA72 and most of the ones I can find are endless.
Can you break a link and install a master link with a clip? I've got a few of those left over. I don't want to accidentally cut off more than I need though.
Like essentially removing one link from the endless chain and putting in a master link/8 shaped piece/clip?
