cb77 cylinders/barrels
honda brian
G'day men of knowledge.
Can you help me with a with a possible problem. I have a cb77 crankcase assembly (cb77e-213496), and I need to know which cylinders/barrels to use on this. I seem to remember reading a thread concerning holes in cylinders or oil supply but can't find it. Did I imagine it?
I have four cylinders/barrels to chose from,so hopefully have one to suit.
Thanks chaps.
Brian.
Thanks chaps.
Brian.
honda brian
Thanks Cliff, I know about the differences as far as CB77/CB72 is concerned. I need to know if there are any differences between early (1962) CB77/CB72 cylinder/ barrels/jugs and late (1966) model cylinder/barrels/jugs, apart from 60mm versus 54mm bore size. I seem to remember a thread about oil holes. Sorry for not making myself clear.
Brian.
Brian.
honda brian
It's not all that important to the discussion, but that the extra oil hole in the front is to feed oil up to the top end from close to the center rather than from the left end. In theory it balances the flow up the left and right outer front studs, rather than feeding it all from the left front stud into the front oil cavity.
presumably the earlier ones tended to leave teh right side short of oil.
All the oil drains down through the cam chain chamber.
And of course there are wide and narrow cam chain tensioners, but I'n not sure which is which - early or late.
