I'm new to the Honda 305. I recently purchased Type 2 CP77 305cc. I think this is 360 where both pistons works at the same time. I wonder if I can change to Type 1 180 where the pistons works simultaneously.
In short - I'd like to change my engine from Type 2 CP77 to Type 1 CB77 (without buying a new engine). Is this possible? Any parts I need to purchase to make this happen?
Please - I need as much information as I can.
Many thanks,
Josh
Modifications from Type 2 to Type 1
Welcome to the forum Josh! Are you sure it's a type 2 engine? Only one set of points? The pistons move up and dowm together? The main differences are the crank, the cams, and the points plate, so all of these parts would need to be replaced. You could grind the alignment post on the cam, and realign the cams 180 degrees apart to reuse old cams. Hope this helps!
type2 vs type 1
Joshes
I have all the parts you will need and am willing to trade for anything that you might have that is interesting!!!!! contact me at mocallaghan@mctdevcon.com
p-town mike
p-town mike
Type 1 to type 2 conversion
If I remember correctly. The pistons for the CB/CL77 are different from the CA77. The differences are the piston tops. CB/CL is higher compression. I had a Superhawk with a Dream engine installed. I like the sound to the Dream engine's exhaust. Sounds like a Triumph.
Dick in Raleigh
Dick in Raleigh
