do all 305 motors rotate the same direction?
MANATEEBREATH
Post by MANATEEBREATH » Wed Dec 05, 2007 8:41 pm
I changed the stator windings in my 65 cb77 starter from a used dream starter.
now it turns the wrong way when I bench tested it?
do the dreams turn the other way from a hawk?
1966 CB77
Re: do all 305 motors rotate the same direction?
Post by LOUD MOUSE » Thu Dec 06, 2007 1:15 am
No. ........................................lm
MANATEEBREATH wrote:I changed the stator windings in my 65 cb77 starter from a used dream starter.
MANATEEBREATH
Post by MANATEEBREATH » Thu Dec 06, 2007 8:38 am
No, what? im sorry I am a little slow
1966 CB77
Post by LOUD MOUSE » Thu Dec 06, 2007 10:09 am
You ask a question. I replied. .................lm
MANATEEBREATH wrote:No, what? im sorry I am a little slow
Post by 305 » Thu Dec 06, 2007 1:26 pm
you actually asked two questions
in the subject line you asked "do all 305 motors rotate the same direction?"
in the body of your post you asked " do dreams turn the other way from a hawk?"
it all depends on on which question is answered .....i believe it was the second one
MANATEEBREATH
Post by MANATEEBREATH » Sat Dec 08, 2007 10:45 am
You are correct that was a lazy post,
problem is solved however.
My starter motor had an open stator winding. I had others laying around so I replaced it with a ca? starter, not sure but it was different than the cb.
The starter then rotated the wrong direction. I disassembled it and found the winding is wraped in the opposite direction from the cb starter.
I switched the brush connection with the power input post on the winding and reinstalled it. works great now....
1966 CB77
